If it is seeping a bit at the edges, first try a warm re-torque.
Check the valve settings after that.
If you need to replace it, the mating surfaces have to be cleaned up perfectly clean, as well as the bolts, threads, and boltholes.
It then needs to be torqued to "spec", in the specified order, and the valves need to be set before startup, followed by a warm re-torque and a re-checking of the valve settings.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
