Re: Farmall Super M wont go into 4th and 5th Gear
Posted by chappie on March 14, 2015 at 02:29:44 from (208.74.247.249):
In Reply to: Farmall Super M wont go into 4th and 5th Gear posted by Janicholson on March 13, 2015 at 21:30:03:
[quote="Janicholson"](quoted from post at 23:30:03 03/13/15) The rails can become rusted tight. Forcing them is usually going to bend a component. If the tip of the shifter is too thick Left and right, it could be hanging up on the 2-3 rail. to check this see if it can be shifted into gear with the lever out, and using a little pry bar. (clutch blocked down is helpful) If it does move, thinning the tip might be in order. Jim[/quote]
Thanks for the advice. However, I can not understand how the rails could suddenly "rust tight". As I said, I was using 4th and 5th gears. I had driven 2 or 3 miles using them. Suddenly they stopped working. I downshifted for a hill, and when I was past that hill, I could no longer get the shifter into 4th or 5th.
I will try to shift it with the lever out. That maks sense!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
