Re: Hydraulics for an I-4?
Posted by Janicholson on March 14, 2015 at 09:28:08 from (63.152.241.241):
In Reply to: Hydraulics for an I-4? posted by Drew W. on March 14, 2015 at 08:55:56:
The mounting bolt pattern is incorrect for the later IH pump. The timing gears are also weak and can fail (causing the engine to stop instantly).
The solution is to use a front engine cover from a SW-4 or late 1950 or 51 or newer W or I-4. these have the correct bolt pattern. (I don't think, but do not know, if the cover from a late H or SH will fit a W series.)
The timing gears need to be changed to increase the reliability in any case, so changing the cover is necessary to access the gears. The relocation of the bolt holes to accommodate the pump (hole is about 1/2 hole off, and is repaired by inserting a stud into the existing threads using locktite stud and bearing mount, then sawing it off flush and redrilling the hole and threading as needed to match the the pump. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
