Pulled the 12V generator back off tractor and tested using external DC to see if it would act as a motor. After pulling apart and sanding armature along with cleaning, it now works using above test method. Hope to get it installed this afternoon and see if all is well. Researching this Delco # 10240 shows this began life on a Oliver in the late 50's. Slight modification of original mounting bracket made it easy to align and a 31" belt fit perfect. This was much cheaper than using a MD generator that I had used in converting my SM. I have had no problem whatsoever using the mounting brackets as the ground point on generators. Thanks for all... Pete in NC
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
