Re: Distributor
Posted by pete 23 on March 15, 2015 at 17:33:29 from (50.33.12.37):
In Reply to: Re: Distributor posted by farmallguy1923 on March 15, 2015 at 16:50:17:
Are you getting a different switch. You need a grounding switch. That would be a single wire switch that grounds the mag when switch is in (off). Of course you can use your battery ign switch if you like. Just unhook the wire coming from the amp meter. Then run a wire from that switch terminal to ground. The switch will work backwards so you will have to push switch in to run and pull out to ground out mag to shut off. Kind of unhandy especially if someone other than you run the tractor.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
