Re: 140 water pump
Posted by Curt Cooke on January 15, 2001 at 13:49:14 from (63.106.164.130):
In Reply to: 140 water pump posted by Bus Driver on January 15, 2001 at 13:21:16:
You are correct, remove radiator. Removing and Reinstalling the impeller, use a press and maybe some heat is about all you can do. The Super A's and C's, 100's and 130's used the same pump.
Post A Followup
: Re: Re: 140 water pump
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
