Re: FARMALL 140 ONE POINT HITCH
Posted by bmd on March 16, 2015 at 10:01:06 from (73.31.111.28):
In Reply to: FARMALL 140 ONE POINT HITCH posted by RUN-N-LATE on March 16, 2015 at 08:37:52:
Try Google for "1 Point Fast Hitch Lift Arm Extension".
I'm not sure Farmall ever made these, but you see these quite often on Farmall Row crops here in the Southeast.
Also, there is small amount of adjustment obtained by adjusting the nut at the end of the rear lift rod.
Hope this help
  Upload Photo  Select Gallery Photo  Attach Serial No List
