I also believe you need to check the marks on the pulley. One way to really be accurate is to make a piston stop out of a spark plug. Gut a used plug for the engine, leaving only the shell. Find a piece of steel rod that fits in the shell and braze it in place sticking out an inch or so. Round the end of the rod into a dome (not accurate or polished, just not sharp edged). Screw it into #1 plug hole (all other plugs out)(with the piston going up, stroke does not matter) Using a hand crank, !!!not the starter!!! roll the engine till the piston touches the rod and stop. Mark the pulley at the pointer. Turn the engine backward (using the fan belt) till the piston touches the rod softly from the other direction. Mark the pulley there. Now use a tape measure to divide the two marks giving a very real TDC. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
