Re: 300 compression
Posted by wayne in MN on March 17, 2015 at 18:58:11 from (97.92.1.19):
In Reply to: 300 compression posted by CNKS on March 17, 2015 at 18:37:20:
Charge your battery and then re-test with open throttle and all plugs out. Compare to first set of numbers. Second test should read higher.
Do you need more power or just want to make the tractor run its best as is?
  Upload Photo  Select Gallery Photo  Attach Serial No List
