Re: What is this and how does it work?
Posted by lfure on March 19, 2015 at 11:03:39 from (68.169.254.14):
In Reply to: What is this and how does it work? posted by SunnyKay on March 19, 2015 at 09:54:37:
I like the looks of it. I grew up around the Case eagle hitch, which is a rigid category one hitch. The hitch you have will work with any cat. 1 implement. To hook up you back the claws up to the implement pin, and close the latches. Then hook up the top link. You will have to remove the short top link that is on it and use a longer one. Maybe we should make a trade. I have a 340 utility with the fast hitch. I bought a set of bars that have the cat. 2 sockets welded to the ends to use to hook up implements. Of course the fast hitch won't spread open like a three point. So I have to put the bars on the implement then have someone hold the bars up while I back into them. It sucks and I hate it. I'm going to cut the sockets off and weld eagle hitch latches to the bars. That is unless you want to trade your hitch for my fast hitch?
