Re: Converting 706 shift to 756 shift
Posted by DeltaRed on March 19, 2015 at 19:01:38 from (65.100.146.10):
In Reply to: Converting 706 shift to 756 shift posted by dwinter16 on March 19, 2015 at 17:15:54:
I've converted 3-4 of them.A '7' is 2" shorter in hieght than all the others,so only another '7' will 'fit'.My own personal 706 has a 'kit' from a 1256.Used a 1066/856 for others.Also put a 1066 into a 1206.That was a direct bolt up.All you have to do is shorten the upright 'rods' 2". then thak the cast steering support and grind out the 'hollow' that the range upright sits against.Really 'hog' it out. Just toss it in the ground and grind away with your 9" anglehead.Then cut out the 'window' for the park lock cam.I am currently makeing up a 'kit' from a larger tractor to be installed in a '7'.Those parts are comeing from Kansas,I will ship back.The adapting of parts takes less than 2 hrs.Call me if you have questions. (970) 874-3973 Steve
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
