Re: Converting 706 shift to 756 shift
Posted by Owen Aaland on March 19, 2015 at 19:03:38 from (216.47.34.37):
In Reply to: Converting 706 shift to 756 shift posted by dwinter16 on March 19, 2015 at 17:15:54:
In addition to the external linkage you also need the range transmission cover with linkage and the high/low shift fork.
Parts from an 856 and up should also work but you will need to cut off the vertical shift linkage shaft and re-drill the hole for the lower arm.
