Re: What Is The Recommended Coolant For Farmall H?
Posted by old on March 20, 2015 at 09:14:24 from (209.86.226.60):
In Reply to: What Is The Recommended Coolant For Farmall H? posted by SouthPaw777 on March 20, 2015 at 06:29:19:
I have switched to the universal antifreeze since I have some newer stuff and not sure if it is the new or old type so that way I have both covered. That way I only need one type on hand. Depending on where you are depends on the mix you want. If up north you may want 70/30 70% antifreeze and 30 water. If your where it does not get way below zero 50/50 is ok
  Upload Photo  Select Gallery Photo  Attach Serial No List
