Re: '40 Farmall H
Posted by charlie M on March 21, 2015 at 04:00:40 from (50.49.118.102):
In Reply to: Re: '40 Farmall H posted by Rwverde on March 21, 2015 at 01:35:59:
A mag and a distributor are 2 different things. They look somewhat similar. A mag is designed for a tractor with no electrical system and if yours is working you can keep it and still have a 12 volt system for your starter and lights. If the mag is not working then the question is does it need new points and condenser (which has to work no matter what) or is the internal coil bad. You can replace the coil or you can add an external coil which you have already bought and make the mag work like a distributor.I don't recall exactly the wiring for that, especially if you are adding an alternator but I'm sure some guys will add to this tread and tell you how it has to go.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
