Re: 300 RC won't start no fire
Posted by John T on March 22, 2015 at 06:25:42 from (71.55.236.60):
In Reply to: 300 RC won't start no fire posted by VaGasman on March 22, 2015 at 05:59:55:
If setting not running with Ignition ON the high input side of the coil MUST be hot with respect to frame ground while the low output side to distributor is usually OFF because the points are usually then closed. With Ign ON and cranking her over a test lamp on the low output to distributor should flash ON when points open but OFF when they are closed.
If it never comes on points are closed or shorted out or the condenser is shorted out or coils primary is open
If it never goes off points are bad or burned or not closing or not grounded or a wires open.
If you work through my Ignition Troubleshooting Procedure linked below it will explain all this in more detail and guide you to the cause of your problem.........
Points are often the cause of a firing problem, they need to be clean and adjusted. Sometimes a condenser or its wiring will get shorted.
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
