The Transmission is getting its liquid from condensation (and some rain down the shifter). The Texas climate has large temp differences every day causing "breathing" into and out of the trans. When in the trans, the moisture condenses on the cool metal and stays. I agree with old. The Missouri tractor likely gets moisture at the joint where the manifold attaches to the exhaust pipe. This perpetually rusty joint is often leaking water from the muffler (a collection device) to that joint. Two solutions for the engine issue: remove the pipe, tap the manifold to get clean threads, put in a new 2" npt black iron exhaust pipe using molybdenum disulfide anti seize compound. Or invent a umbrella for under the muffler that directs rain off of the hood and doesn't touch the hood. A CV joint boot with a small axle end hose clamped to the base of the shifter can keep some of the rain out of the Texas tractor (and Missouri as well). Working the tractors often will heat the oils enough to drive moisture out. When these were the main use tractors the issue never became obvious. A they are used today, the heat is usually minimal and the H2O builds up. Jim
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
