True 12 Volt coils have more primary turns/windings.
As to using a 6 Volt coil on 12 Volts, in addition to it getting HOT, it doubles the current through the breaker points.
It's pretty much accepted that in common practice ignition points typically switch between 3 and 4 Amps, and when you start to get above that, they get hot, burn, pit, etc..
Also, you wrote " some have more resistance so are called "internal resistor" coils".
NOT by anyone but the uninformed.
While there were some such oddities 80 or so years ago, I don't believe you will find ONE single example in the modern era of a coil labeled "internal resistor".
Coils requiring an EXTERNAL resistor are so labeled, but you won't see one labeled "INTERNAL resistor".
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
