Posted by kossuth on March 22, 2015 at 20:34:44 from (76.106.12.192):
In Reply to: bolts for my M posted by scott wallace on March 22, 2015 at 18:07:22:
I'm alittle confused here. If you got 8 bolts per rim that tells me that most likely what has happened is your tractor had 400/450 rim centers installed at one point for XYZ reason. Definately not the end of the world. Problem is they don't list jam nuts for use with a 400/450 center that I saw. If it is a 400/450 center the bolts are cheap enough. You can pickup new bolts for about $1.80 a pop if you actually have 400/450 centers on that tractor. Now the clamps, and the nuts on the bolts are a different story. Now the nuts for whatever reason are about $5.50 a piece for the nuts and about $23 for the clamps. Not sure what's so special (maybe because they have a square vs hex head???) but they definately aren't cheap.
If you have miscounted and actually have the original 6 bolt rims then the bolts are about $5.50 a pop, but that fellow uses jam nuts and such like you're describing.
Either way you're gonna spend some money if you replace with original hardware.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
