Re: 1972 IH 140 Keeps burning up coils - HELP
Posted by John T on March 23, 2015 at 07:41:39 from (71.55.236.60):
In Reply to: 1972 IH 140 Keeps burning up coils - HELP posted by Nawlens Gator on March 23, 2015 at 07:23:22:
If it was converted form 6 to 12 volts and you still have the 6 volt coil (but no external series voltage dropping 12 to 6 ballast resistor) THE COIL WILL GET VERY HOT and can eventually fail totally plus the elec switch switch (or old points when used) can go bad.
Do you have a 6 or 12 volt coil????????
If a 6 on a 12 volt tractor, add a series voltage dropping (12 to 6) external Ballast Resistor or else toss the coil and get a new full true 12 volt rated (NO ballast required) coil
Its best to match the coil polarity to your ground. For Neg ground the coils POS wires to ign switch output and its NEG wires to distributor
Questions???
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
