Re: 1972 IH 140 Keeps burning up coils - HELP
Posted by John T on March 23, 2015 at 11:26:36 from (71.55.236.60):
In Reply to: Re: 1972 IH 140 Keeps burning up coils - HELP posted by 87nassaublue on March 23, 2015 at 10:40:22:
87 Blue, you're on the right track, but to clarify a few loose ends let me add these comments to your post with all due respect:
1) "The purpose of a ballast coil is to boost the output of the coil during cranking."
That's indeed true in that it boosts the coil output while cranking, but its the coil in conjunction with THE BALLAST BY PASS SYSTEM that does the job.
The way I would explain it is: The purpose of an externally ballasted coil coupled with a BALLAST BY PASS (while cranking) SYSTEM, is so the ballast can be by passed while cranking (when battery voltage is reduced) so the entire unballasted battery voltage (be it 12 or reduced to 10 due to cranking voltage drop) is applied to the coil momentarily which increases spark energy to improve cold weather starting. If you have a 6 volt coil and an external voltage dropping (12 to 6) ballast resistor, what happens is while cranking you remove the ballast so the 6 volt coil sees the unballasted 12 down to 10 or so volts (NOTTTTTTT the normal 6) to increase spark energy. Without the ballast and by pass system that's not possible.
2) "Cranking pulls the battery down and therefore lowers the output of the coil. To compensate for this on cars and trucks, The ballast coil was introduced."
Id say to compensate a coil coupled with an external ballast resistor and a ballast by pass (while cranking) system was introduced.
3) "The coil is wound so it gives full output at a lower input voltage."
SORRY I CANT AGREE WITH THAT
The coil DOES NOT gives its full output at a LOWER input voltage, actually its output is less if voltage is reduced.
4) "It's fed via the ballast resister which reduces the voltage into the coil which would end up being around 7 volts. During cranking, the ignition switch would short out the resistor to increase the input voltage to a full 12 volts and therefore the output of the coil for better starting."
You got that part basically correct
Hope this helps clarify things a bit
Best wishes n God Bless
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
