Re: Trailer question
Posted by Haas on January 16, 2001 at 05:21:21 from (129.37.117.34):
In Reply to: Trailer question posted by Phlogiston on January 15, 2001 at 19:40:33:
Bama Binder is giving you good advice. You will need two chains and two load binders to tie it down. One set is to keep it from going forward and the other at the front to keep it from going back. Run the chains across the trailer to tie points at the approximately the corners of the trailer and at the center of the front and rear of the tractor. The rear drawbar and the cultivator attach point at the front of the tractor are good tie points. Make sure the chains are tight! The tractor should be far enough forward to put about 500 lbs of weight on your truck hitch. When you load it, measure the tongue height before and after loading. The tongue should go down a couple of inches.
Post A Followup
: Re: Re: Trailer question
