Re: '45 H transmission seal
Posted by wayne in MN on March 23, 2015 at 13:36:59 from (97.92.1.19):
In Reply to: '45 H transmission seal posted by NEJake on March 23, 2015 at 09:43:20:
Remove the belly pump & loosen the driveshaft bolts to remove the coupler.
Here is the method I have used several times:
When loosening the drive coupling bolts (after the nuts have been removed) lock the shaft to prevent rotation and find a LONG handled combination wrench and turn the bolt to remove. Takes a lot of force (the bolts are tapered) to turn the bolts so an "extension" on the wrench is handy. It will "snap" when the bolt comes free. This process works much easier than trying any other method.
Good luck.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
