Re: Farmall H water pump.
Posted by chad from michigan on March 23, 2015 at 16:33:06 from (162.247.145.197):
In Reply to: Farmall H water pump. posted by chad from michigan on March 22, 2015 at 19:34:01:
Ok found the problem on the fan that was causing the noise. Took the belt off the fan and started spinning it narrowed it down to the spring things on the front of the fan assembly closet to the radiator. I taped both sides up so it could ed move and spun the fan and the noise went away. Took tape off and spun the fan and those things rattle they look pretty worn out. Are the spring wore or the guide pins bad? What exactly are these spring loaded things for? Can I fix it?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
