Re: found Crack in block
Posted by CenTex Farmall on March 23, 2015 at 21:17:45 from (72.105.160.30):
In Reply to: found Crack in block posted by chad from michigan on March 23, 2015 at 16:49:03:
Annoying for sure but repairable. You can try
the JB weld, if it doesn't hold then you can
braze it. If it came to it I would braze over
arc welding but an expert could do it. My luck
with welding cast is about 50/50.
The trick with JB weld is cleaning the base
metal. After you grind the area you want to use
_acetone_ to remove all oil residues. I think I
found that info on the JB website. Even some
brake cleaners can leave a residue.
The second trick will be keeping the area warm
while the JB cures. A heat lamp could work if
you're parked inside. Then too you'll have to
babysit the stuff for the first hour or so as
it will want to ooze down. Not a big deal but
you don't want to do it twice.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
