The push button switch you have now lines up perfectly with the 5/16" bolt. The foot operated lever WILL NOT line up with that same switch. You would need to also swap the rear gas tank support for the newer style which locates the starter switch properly to line up with the foot operated lever.
Easiest, and best way to solve the dilemma is to convert to the LATE style, steering post mounted starter switch. Then you can use your left hand to operate it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
