With the ohm reading you are getting on the primary of the coil it should not need a ballast resistor. I think the idea of excess dwell time has merits. I would be trying to run a test to see just how many degrees that unit is turned on. Or, just put the points back in and run it for a while to see how the coil reacts then. As far as the apparent high discharge reading on the ammeter when the problem showed up, I would just leave the switch on when it dies and quickly disconnect the feed wire to the coil to determine for sure if the coil was drawing the current or some other circuit.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
