Re: Alternator conversion
Posted by Janicholson on March 24, 2015 at 20:21:12 from (63.152.241.241):
In Reply to: Alternator conversion posted by tractordanp on March 24, 2015 at 17:06:50:
The 3 wire is easy. You will need a trailer marker light (or a dode, or a 10 ohm 10 watt resistor) and some 14 gauge wire and maybe some 10 gauge wire. The Battery (stud) on the Delco goes to the wire that was connected to the Bat terminal on the regulator. (a terminal end and a piece of 10 gauge wire to connect might be used). the #2 terminal also connects to the Big Bat stud on the Delco. The #1 terminal connects to one terminal on the marker light bulb, the other marker light terminal connects to the ignition switch side of a ballast resistor (if using the 6v coil) and the bulb is the idiot light as in a car. The coil should have its wires reversed Negative to the distributor) and the amp gauge swapped wies side to side. (shows charge correctly) Bulbs need to be changed to 12V. If using a resistor in place of the marker bulb, no difference, if using a Diode, the marked end of the diode goes toward the alt. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
