Re: 1972 IH 140 coil UPDATE w/Data
Posted by Owen Aaland on March 24, 2015 at 23:57:13 from (216.47.34.37):
In Reply to: 1972 IH 140 coil UPDATE w/Data posted by Nawlens Gator on March 24, 2015 at 11:13:32:
The output side of the coil should be either the same as input voltage or zero. The reading you get is an average of the two conditions.
What you are seeing would be bad if using a points distributor but with an electronic set up the readings may be normal. Contact points need time to physically move but the electronic system only needs to open the circuit went a spark is needed.
