Re: 1972 IH 140 coil UPDATE w/Data
Posted by Nawlens Gator on March 25, 2015 at 11:39:12 from (184.46.86.83):
In Reply to: Re: 1972 IH 140 coil UPDATE w/Data posted by Janicholson on March 25, 2015 at 10:53:45:
I'm beginning to understand. Found this: "The period of points closure is typically expressed as degrees of distributor rotation. In a four cylinder engine, the angle between each ignition cam lobe is 90° and the period of points closure or "DWELL" is usually a bit over 45° of distributor rotation."
So you're saying coil heating occurs when the points close (ON). Looks like that's about half the time. When the points close, does the current flow through the coil to ground?
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
