Re: Farmall M unknowen pto unit
Posted by 590cummins on March 26, 2015 at 09:00:30 from (173.209.212.144):
In Reply to: Farmall M unknowen pto unit posted by 590cummins on March 23, 2015 at 09:32:27:
Well not too much it has the orignal rearend. The time lines dont match up to be the rearend off of an m-ta because it has the break bands not the disc brakes an it has the crooked gear shift with orignal cap seals in the shifter pivot pin. Also I took a close look an the bolt pattern is a little different than an m-ta or that of a 400
