Re: Long 460 Clutch not disengaging
Posted by thecarpenter on March 26, 2015 at 19:48:56 from (108.230.206.151):
In Reply to: Long 460 Clutch not disengaging posted by Triliji on February 23, 2015 at 12:18:19:
Just wondering how you are coming in your clutch repair. I have the same tractor with same problem and have never split a tractor before. Where did you get your parts from. How to know if you need a 10" or 11" so I can order ahead of time . Would be interested in corresponding with you further. THanks
Greg
