Re: Roosa master injection pump
Posted by Wardner on January 16, 2001 at 16:31:09 from (63.23.215.161):
In Reply to: Roosa master injection pump posted by 560D on January 16, 2001 at 07:11:58:
All right I will take a whack at this seeing as nobody else has. Even though I have a 660 I have not done this. You need to remove a rectangular plate (5/8 x 1 1/4) on the side of the pump. It is held on by two machine screws. Rotate the motor slowly until you see a deep hole. At the bottom of the hole will be an allen-head screw. Probably 5/32 socket. It will require maybe 25-40 ft-lbs to turn. Turn clockwise to increase fuel. Start by turning only 60 degrees. Put the small plate back on and start the tractor. You should see a significant increase in power at full throttle. If it is not enough power turn the screw another 60 degrees. I would not exceed 180 degrees total. This adjustment is usually done when a turbocharger is added. Your exhaust will blacken appreciably without one. Another easy way to increase power on a diesel is to inject propane vapor in the intake. You could probably get 25-30 hp. You should also check your throttle linkage to make sure the pump is actually at "wide open throttle". I realize that diesels do not have throttles but I think you know what I mean.
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
