Re: Re: Roosa master injection pump
Posted by Wardner on January 16, 2001 at 19:15:24 from (63.23.215.161):
In Reply to: Re: Roosa master injection pump posted by Les Repair on January 16, 2001 at 17:09:49:
I defer to you Les. The procedure I described works on Stanadyne pumps. Both types of pumps look similar from the outside so I figured they were similar on the inside.
Post A Followup
: Re: Re: Re: Roosa master injection pump
