Re: 6V to 12V Conversion
Posted by Red Dave on January 17, 2001 at 11:39:27 from (208.165.46.34):
In Reply to: 6V to 12V Conversion posted by Tim on January 17, 2001 at 09:29:52:
12 Volt will turn the starter faster thereby covering up a lot of tune up problems. 6 Volts turns the starter plenty fast enough provided:
The tractor is tuned up properly
The battery is charged
Large enough cables are used from battery to starter
Battery and starter connections are clean and tight
Remember, most of these old tractors were made that they could be hand started. Electric start was an option for many years and 6 volts sure beats a hand crank in my book. There is no question that the 6 volt system requires a bit more attention to maintenance. If you want originality, keep the 6 volt system. If you are having problems, and you need reliability on a working tractor, check out the article archives on the left. There are several articles on the subject, including a step by step guide for the conversion process.
Post A Followup
: Re: Re: 6V to 12V Conversion
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
