Re: Re: Re: clutch pedal
Posted by Dan on January 17, 2001 at 22:15:56 from (12.18.161.164):
In Reply to: Re: Re: clutch pedal posted by JohnIH on January 17, 2001 at 11:52:21:
I had that problem on my SMTA, both shaft and pedal were worn. I used the washer trick above and helped some but finally ran a piece of strap metal foreward bolted to where the clutch return spring anchors, runs next to the pedal then ran a short piece out from the top of the center housing bolted to this one. Sort of a 2 sided box setup. Not as pretty as it could be but keeps the pedal from going past the corner of the platform. Saw one at a show with a piece welded on the bottom of the platform on the outside of the pedal to hold it in. At least my version is removable if and when I can fix the problem right. Noticed Denny's Carb Shop lists the cross shafts for $45 whick doesn't sound too bad but you would still need to bush the pedal
Post A Followup
: Re: Re: Re: Re: clutch pedal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
