Farmall Tractors Discussion Board
Re: 200 serial # missing
Posted by Jim Becker on January 24, 1999 at 20:47:03:
In Reply to: 200 serial # missing posted by Dave on January 24, 1999 at 12:32:50:
The engine number is of limited value in determining the serial number, although both reportedly started at 501. There were only a few hundred built in '54, with the rest split pretty evenly between '55 and '56. Look for codes on the large castings. They look like (*2.24.Z*) where Z='54, A='55 and B='56.
Post a Followup
: Re: Re: 200 serial # missing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
