Re: hydraulic conversion for farmall a
Posted by Stan(VA). on January 18, 2001 at 14:56:15 from (198.77.116.58):
In Reply to: hydraulic conversion for farmall a posted by matthew on January 18, 2001 at 06:00:07:
It depends on what you want. If you just want functionality, a power steering pump from a fan belt, a PTO pump, or an electric pump are all options. If you want what looks like factory on a SA, you need an engine block, pump, manifold, torque tube, gas tank, steering collumn and probably a few other odds and ends I forgot. Seriously, the easiest for this would be buy the SA and sell the A.
I took a hybryd approach to this when doing a B, I got a new engine block, pump, manifold; modified the manifold end and routed hoses to my own valve and reservoir.
Stan(VA).
Post A Followup
: Re: Re: hydraulic conversion for farmall a
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
