Re: Adjusting front axle width on A - Pretty tough job
Posted by Hendrik on January 19, 2001 at 13:20:14 from (62.100.12.1):
In Reply to: Adjusting front axle width on A - Pretty tough job posted by David A on January 19, 2001 at 05:12:33:
It is a tough job indeed. I succeeded in removing both on my '48 Super A. Plenty of penetrating oil and patience are required. After removing the tie rods I put most of the effort in TWISTING the axle. Use the knuckle as a lever and lengthen it with a beam or long pipe as necessary. Once it turns, keep twisting it to and fro while exerting an axial force on it. It will come out finally.
A good torch might help a lot in the process. I must admit mine were moved at some time, between 1948 and 1998... ;)
Good luck, Hendrik
Post A Followup
: Re: Re: Adjusting front axle width on A - Pretty tough job
