M Compression
Posted by Blu on January 19, 2001 at 14:36:33 from (4.54.41.253):
I got a compression Tester for Christmas and not sure what to do. Should I remove all the plugs while performing the test,or just remove the plug from the cylinder that is being tested. I did a test with leaving them in exept one and got 90psi. I always heard you should at least have 100psi. The tractor runs good. Any help would be great.
Post A Followup
: Re: M Compression
