Re: Re: Re: Re: Re: Need help removing of counter shaft oil seals on my H
Posted by Haas on January 20, 2001 at 07:00:58 from (129.37.117.127):
In Reply to: Re: Re: Re: Re: Need help removing of counter shaft oil seals on my H posted by Neal (TX) on January 20, 2001 at 06:52:34:
If you are talking about the coupling on the lift all which must be removed to replace the lift all seal, it also unscrews counter clockwise. It can also be real hard to get off. Some folks say to stick something in the pump gears to hold it while you put pressure on the coupling to unscrew it. I was reluctant to use anything metal so ended up taking the liftall apart. Had to clamp the gear in a vise between two blocks of wood with half circle cut outs the diameter of the gear and then insert a bar in the coupling and hammer several times real hard to break it loose.
Post A Followup
: Re: Re: Re: Re: Re: Re: Need help removing of counter shaft oil seals on my H
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
