Re: Re: Re: Re: Re: Need help removing of counter shaft oil seals on my H
Posted by The Red on January 20, 2001 at 07:13:37 from (12.75.221.167):
In Reply to: Re: Re: Re: Re: Need help removing of counter shaft oil seals on my H posted by Neal (TX) on January 20, 2001 at 06:52:34:
Neal I doubt that pounding will do any damage. Two or three good wacks and a few choice words ought to jar it loose. Make sure the transmission is in gear and the brakes are set.
I use a long large screwdriver up the pump input pipe to keep the gears from turning while removing the liftall countershaft dog. As Haas mentioned, it unscrews counterclockwise also. Good luck!
Post A Followup
: Re: Re: Re: Re: Re: Re: Need help removing of counter shaft oil seals on my H
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
