Re: starting woes on 350
Posted by Wayne on January 22, 2001 at 18:23:18 from (152.163.213.76):
In Reply to: starting woes on 350 posted by joe on January 22, 2001 at 17:34:59:
I have a 300 that starts similar to this when it is cold. It takes off right away then immediatly dies. It must be cranked a little bit on full choke, then it takes off again and runs fine. At first I thought it was getting flooded. It would not crank much after that first pop, and I would have to charge the battery. I recently converted it to 12volts and put in a new battery. It has enough power now even in the cold to crank over quickly after that initial pop, and does fire up and runs fine. I don't think that air getting in around the hose will affect it as this is still ahead of the choke plate. It may just alow some dirty air in.
Post A Followup
: Re: Re: starting woes on 350
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
