Farmall Tractors Discussion Board
Re: Electronic ignition for IH
Posted by steve on January 26, 1999 at 09:02:30:
In Reply to: Electronic ignition for IH posted by DY on January 26, 1999 at 06:04:23:
DY,
There is a company on the net selling 12v electronic tractor ignition retrofit kits, but nothing for 6v. They have an occasional ad that
appears at the top of this page.
For engines that are reluctant to start at low
temps, I would always make sure the choke is fully
closing, and that the rest of the ignition and fuel systems are up to snuff. New dist. cap, points, rotor, condensor, ign. wires, plugs, etc.
Drain the gas tank and replace the gas, if it is
old or stale, and use STABIL (or some fuel preservative) in the truck, if you only drive it
rarely. If compression is low, that will make cold winter starts tough. Using a block heater is
always a good idea, so keep doing that.
There is *no reason* a 6v and/or a conventional ignition (not HEI or electronic) cannot start and
run just fine at low temps. My Farmall A has started without protest many times at temps well below zero. 6v, points, etc. - no electronic anything.
Electronic ign. might help on-road performance (horsepower) slightly, but before you'd notice a big difference, you'd have to change a lot of the other design elements in that engine.
Steve (Colorado)
Post a Followup
: Re: Re: Electronic ignition for IH
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
