Re: 12v conversion on farmall cub
Posted by John on January 23, 2001 at 22:13:59 from (208.0.21.187):
In Reply to: 12v conversion on farmall cub posted by ange on January 22, 2001 at 16:39:10:
Having done one 6 to 12 volt conversion, I found myself asking why afterward. The reason I was aking why is becaused I realized there is no reason to convert only excuses. The 6 volt system was only abandoned by the auto industry because the 12 volt system cost less to install per unit. In short the bean counters made the call to go to 12 volts.
Post A Followup
: Re: Re: 12v conversion on farmall cub
