Re: Wide front for Farmall B?
Posted by Red Dave on January 25, 2001 at 08:21:09 from (208.165.46.34):
In Reply to: Wide front for Farmall B? posted by Dave on January 25, 2001 at 06:38:26:
To put an A front end on a B would require transfering the steering gear as well as the axle assembly. The A and B blocks are the same so either steering gear should bolt on either block. The grills are different at the bottom because there are differences in the way implements are mounted. You would lose the front implement mountings of the B, hence the difference in the bottom of the grills. I can't recall right now whether the steering wheel shaft will bolt up or would need some modifications. Also, I think the hoods are the same so unless something was mounted cockeyed they should mate up.
Please tell us that you don't want to put the B front on the A though. I don't want to read about somebody killed in a rollover.
Post A Followup
: Re: Re: Wide front for Farmall B?
