Re: 784 international pump timing
Posted by JimB2 on March 13, 2009 at 19:47:44 from (99.241.179.24):
In Reply to: 784 international pump timing posted by bender on March 13, 2009 at 16:16:28:
Hi Bender, hope you didn't loosen the cap screws on the pump gear. If you marked the mounting bracket and the pump then the pump will either be almost in time or 1/2 a revolution out of time as the pump only turns at have the speed of the engine. There is a procedure in the shop srvice manual to do static timing of the pump.
JimB
