Farmall Tractors Discussion Board |
Re: farmall 330 crankshaft
Posted by Harold H on January 26, 1999 at 17:48:58:
In Reply to: farmall 330 crankshaft posted by markw on January 26, 1999 at 17:13:43:
Mark, The 330 engine is 135 cu in with 3 1/4 bore x 4 1/16 stroke. The 300 engine is 169 cu in with 3 9/16 bore by 4 1/4 stroke. The 350 engine is 175 cu in with 3 5/8 bore x 4 1/4 stroke. I think, but am not sure, that all three of these use the same block and should work but check before you buy one as the journals could be different. If the 300/350 crank will work it should give you about 145 =- cu in displacement. Harold H
Post a Followup
