Re: Need some parts to attach a 54A plow/grader front blade to my 50 Cub
Posted by Jim Becker on January 27, 2001 at 09:29:57 from (216.51.108.13):
In Reply to: Need some parts to attach a 54A plow/grader front blade to my 50 Cub posted by fred Sachtleben on January 26, 2001 at 16:41:27:
I have a sketch of the bellcrank extension if you find you need to make one. The 650268R3 Plate would be pretty easy to make and I can measure one if needed.
The other two bring up a question. The part numbers you list ar for the L-54 blade for a LoBoy. The Cub-54A parts are 651257R1 (brace) and 651259R1 (lever).
By the way, the correct blade is 54".
Post A Followup
: Re: Re: Need some parts to attach a 54A plow/grader front blade to my 50 Cub
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
