Farmall Tractors Discussion Board
Re: Re: Farmall B Rear-Mounted Mower
Posted by Jim Becker on January 26, 1999 at 20:08:42:
In Reply to: Re: Farmall B Rear-Mounted Mower posted by Todd Markle on January 26, 1999 at 12:50:53:
Yes, similar to the A mower. The B-16 was fully mounted. The "drawbar" (mounting frame) bolted to the right, the same as on an A. The left side, as I recall, bolted up to the 4 center mounting holes (2 each side) at the inner ends of the axle extension housings. The drawbar for the BN would be 4 inches narrower than one for a B.
The B could also use the 25-V semi-mounted mower. It bolted to the stndard drawbar and had a tail wheel.
Post a Followup
: Re: Re: Re: Farmall B Rear-Mounted Mower
