Re: M Engine
Posted by John In Iowa on January 29, 2001 at 07:09:09 from (199.108.164.13):
In Reply to: M Engine posted by steve on January 28, 2001 at 18:37:09:
One question? Did you plane the manifold. This is one step that is often overlooked when doing an overhaul and causes many headaches afterwards. You can check to see if its leaking before pulling the manifold off by shooting some light oil around the manifold and listen to hear the engine run a little better and hear the oil being suck in around the manifold. If you use carb clearer, you will hear the engine run better.
John In Iowa
Post A Followup
: Re: Re: M Engine
